no fp light
Re: no fp light
When testing on a Stim, do you get an RPM signal in Stim for Wheel mode?
Re: no fp light
it raises up slightly but its still in the yellow, 182rpm. only last a secMatt Cramer wrote:When testing on a Stim, do you get an RPM signal in Stim for Wheel mode?
Re: no fp light
installed it in my car without injectors connected with stock ecu controlling everything to see if i could get an rpm signal. i could get rpm but i couldnt get a steady signal that last. i may have bad pots. im going to ohm them out. i know they dont click when fully turn ccw. how many turns are these pots?
Re: no fp light
checked my timing, it was off a bit. retime the car and played with the pots. it was a bit better but i think it needs to be better
Re: no fp light
tach also drops out when hit throttle
Re: no fp light
better rpm signal but it still drops out on throttle
Re: no fp light
If you are losing RPM, please post a tooth log of the problem. This is a special purpose log for dealing with RPM input problems.
Re: no fp light
i wasnt getting any tach on this because my car wasnt warm and was at 1k. any below that it will see it and i get rpm
Re: no fp light
If it seems to drop out with it cold, try adjusting the VR trim pots.
Re: no fp light
I just replace d24 and still have the same problem. It don't matter if it's cold or hot, if I hit the throttle its gone.
Re: no fp light
I noticed there is no d1 or d2 installed,they aren't jumpered or anything. Is this Norman?
Just noticed that's for the opt circuit
Re: no fp light
....which you shouldn't be using for the crank sensor.stoney0024 wrote: Just noticed that's for the opt circuit
Adjust the VR trim pots.
