MS1 wasted spark 2 cylinder setup
blitz102rus
Post by blitz102rus »
hi guys I'm newbie and I'm megasquirting inline twin with MS1 v3 extra(fuel and spark)
manual(http://www.msextra.com/doc/ms1extra/MS_ ... #2cylinder) says
PLEASE NOTE, IF YOU PLAN TO RUN IGNITION ON A 2 CYLINDER ENGINE THEN YOU MUST SET THE ENGINE UP AS A 4 CYLINDER USING THE WHEEL DECODER (36-1, ETC) AS THE CODE FOR IGNITION WILL HAVE TOO LONG A DELAY TO WORK CORRECTLY.
ok, but the picture confused me
what is correct?
second question about wheel decoder xls, it has options for 2 or 4 cyl, I must use 4 cyl option?
Re: MS1 wasted spark 2 cylinder setup
Post by Matt Cramer »
What sort of ignition are you using?
blitz102rus
Matt Cramer wrote:What sort of ignition are you using?
direct coil control with this hardware mod http://www.msextra.com/doc/ms1extra/MS_ ... singlecoil
And what are you using for RPM input?
blitz102rus
VR-sensor and 12-1 trigger wheel
DaveEFI
Post by DaveEFI »
Think the 12 cylinders in the pic may be wrong?
Please post your MSQ.
old guy
Post by old guy »
Is it a 180 or a 360 deg twin?
blitz102rus
DaveEFI wrote:Think the 12 cylinders in the pic may be wrong?
exactly
old guy wrote:Is it a 180 or a 360 deg twin?
360 deg
Matt Cramer wrote:Please post your MSQ.
ok, in the evening I'll try to start the engine and post it) maybe some logs will help?
blitz102rus
still cant get it running
it has fuel and spark, but not even pops
I see you've set trigger positions A and B identical. If you are using the "pretend it's a four cylinder" trick, enable spark B and set trigger position B to be 180 degrees out - in your case, that would be 11 for Pos B and 1 for Return Pos B.
