Won't rev past 2700 rpms, datalog/tune
2005 IS300
turbocharged
diyauto trigger wheel
vr sensor
ford coilpack w/ direct drive
Car runs great up to 2700 and hits a rev limiter it feels like. Almost like a 2 step. Launch control disabled, overboost disabled, rev limits right. No reason for the limit. The datalog shows some spikes in the iat, clt, and rpm. Tooth logger looks very clean.
turbocharged
vr sensor
Re: Won't rev past 2700 rpms, datalog/tune
It's losing the RPM signal. Please post a tooth log of what happens.
thanks. not sure how to save the log file, hopefully i did it correctly.
The Spark C LED flickers while the car is running as well. Not sure if it has anything to do with the issue. Spark A and Spark B stay constant.
You saved it correctly.
Try a 10K resistor in line with the VR sensor input, and adjusting the trim pots.
Tried the trim pots with no improvement. I'll give the resistor a shot.
the 10k ohm resistor took care of the issue. Thank you for a painless solution.
