Fuel pump and idle valv
I have a Megasquirt 1 v3.0
I think I have som problems whit my MS
- When i start the engine it get up the 4000 rpm, but when i disconnects the idle valv it only get up to 1000 rpm. I have tride to change various parameters in tunerstudio but nothing different happens. Can i have wired it wrong? ( +/-)
I have checked the Valve and it seems to work.
- The fule pump does not start. Should i have 5 volts from pin 37?
Re: Fuel pump and idle valv
with the fuel pump bypassed i made these logs.
one is no bypass.
No idle valv !
one is no bypass.
No idle valv !
Pin 37 is a switched ground for the fuel pump relay. The other side of the relay goes to +12v. It normally runs for a second or so at switch on, then only runs again after seeing the tach signal when cranking and running.
okey. I am new at this, (and i´m from sweden so i can have problem whit the language)
But the tach wire is already connected to vr?
I have 5 volts from pin 5. D19 is lose from the board, can that be the issue?
I have a photo of the board
Removing D19 is often done to troubleshoot if the diode is burnt out.
okay. but when it is loose, could it do so I have 5 volts at pin37?
My fan was directly connected to the MS without relay. Could it have damaged the box so I get 5 volts?
Unless you built a special 40 to 50 amp output to drive the fan, you probably damaged the MS trying to direct drive a fan.
No, it what was wrong wiring.
what can I do? which componet get damaged do you think?
The engine works if the fule pump is bypassed. So i can make it separate.
