E85-Petrol
E85-Petrol
Hello
When I alter the fuel between E85 and normal pump gas, I change the req-fuel,. But I also have to change the cranking pulse widths, dont I?
The cranking fuel amount isnt affected by the req-fuel setting?
/Lars
/Lars
Re: E85-Petrol
yes, you have to change cranking table, and after start, warm-up and AE enrichment too..
1978 vw golf gti 16v itb cop full sequential MS2
1992 vw corrado 16v moonlight blue MS2
Re: E85-Petrol
Consider upgrading to MS2 or MS3 that allow a flex-fuel sensor to be used for automatic adjustment.
Re: E85-Petrol
Yes, maybe I should go for a more modern ms-version. But I just go to petrol cos its time to put the car away for winter storage, otherwise I always run it on E85.
/Lars
/Lars
Re: E85-Petrol
If I choose to go for ms2 instead. Will it be a lot of adoption of the whole system . I now have ms1v3 MSnS and I would then run the ms2 the same way. It would be pretty straight forward to switch to ms2, wouldnt it?
/Lars
/Lars
Re: E85-Petrol
There is a bit of work involved. Take a look at the 'Upgrading' section of the manual.
Re: E85-Petrol
Yes, OK. I have the whole long winter to do it, Ill consider it. I havent upgraded the TS or Mega Log viewer, mine are at least one upgrade old. suppose I should start with that.
/Lars
/Lars
Re: E85-Petrol
I upgraded from MS1 to MS2 specifically for the Flex Fuel capability. The upgrade was straightforward.
