Hi All...
Upfront I have an msq & Datalogs to post but rather looking for advise on where to look...
Setup on a 1.5JZ-GTE I6, wasted spark on individual coils (Dwell 2.1ms). 36-2 crank pickup, through a JBPerf VR dual Board (Using only 1 channel)
Car was running spot on until owner rebuilt the block....
Problem is....
Starts Perfect, Idles Perfect....
Up the RPM to ~1200 rpm spark starts to misfire (also visible LED stutter along with Definite Misfire)
then above ~1250ish clear again...
Then starts again at ~2300rpm same issue... Above that clear again...
Not to sure at any higher rpms as I don't see or hear anything (But possibly there) Don't want to damage motor - Drag Engine 2.2bar boost.
Datalogs Show Definite RPM bounce at these points, But so does the Batt Voltage...? Even with Alternator Off (Completely)
Using TS I see on teeth logger every now and again a "drop out" of a tooth, But Scoping the sensor directly shows Clean signal, Post MAX 9962 signal shows a "Glipse" on the input signal.
Any Suggestions on where to CHECK? Please any advise would be Good.
I Can post data if needed.
Regards
Gordon.
Strange 2 Place Spark misfire issue?
Re: Strange 2 Place Spark misfire issue?
Quick Update!!
Problem Solved!!
It all came down to a missing contact spring inside the COP Coil on Cyl 1.
was causing noise due to the arc over inside the COP coil on to the plug terminal.
Shows you what a silly little spring can do..
Problem Solved!!
Well done
It is the small things that catches one out
Gavin
Gavin
