Removal of MS1
Removal of MS1
Hi, after all of my attempts at trying to learn MS, I learned quite a lot btw, I decided to remove it. I had to replace my entire engine harness to do so. Here is the last step that I need someone's help with. My Crankshaft position sensor is from what I believe to be a Ford Escort due to having a EDIS-4 System. So in order to reuse the sensor, I need to know what the wire colors are. I have google to no avail. One is white and one is blue. Could someone help me? Thank you in advance.
Re: Removal of MS1
Doesn't really matter - the signal is AC. If the signal winds up being 'backwards', you can change the input polarity in the TunerStudio settings.
Re: Removal of MS1
Thank you for the reply. For some reason I am now having a no spark/no fuel problem. I'm sure I'll get it sorted out eventually.
