ms1 v3 firmware pb
ms1 v3 firmware pb
Hello I try to upgrade my ms1 v3 but i have a pb
I have make a little video https://www.youtube.com/watch?v=j-YWP6f-EXI
This should count up to 1700+ lines
src\download.exe -c1 msns-extra.s19
MS Download 1.10
! - whatDownload failed:
Expected response "
Boot>",
but received this "! - wha".
Press any key to continue . .
If you can help me thank you
MS Download 1.10
Expected response "
Boot>",
Re: ms1 v3 firmware pb
I have reloaded ms1/extra rev 029y4
I have a coil et la 36/1
I have plug vr sensor avec le + en 24 & - on ground
I have plug
TACHSELECT & VRIN
VROUT e& TSEL
but I dont found a cranck signal
I have plug
TACHSELECT & VRIN
VROUT e& TSEL
Please post a tooth log of an attempted start.
thnak you
It's failing to see real teeth. Try adjusting the VR trim pots or a tighter sensor gap.
hello i have try
But i have few explosion
https://www.youtube.com/watch?feature=p ... cUCr56Q8fc
I need a build rpm tack on my ms1
I have try to plug js0 to output iac1
and S12C to JS9
but my megasquirt stop if you have a solution?
and S12C to JS9
Have you confirmed timing is correct with a timing light?
I am correct timing 66°trigger angle
