Ms1 v2.2 water injection help
boostin
Post by boostin »
Good evening
I am looking for some help setting up water injection with my megasquirt. I have read the instructions and feel very confused if anyone has any pointers it would be appreciated.
I am running at AEM pump and nozzle, and plan to use the megasquirt to control it. at the moment I do not have a solenoid for it I would like to run it at least for now without the solenoid.. sadly no extra money but need to run the water injection.
Also what terminals of the db37 do you use for the pump and solenoid?
1989 Mitsubishi Mighty Max 4WD 2.6 MS1 V2.2
1989 Mitsubishi Mighty Max 2WD lowered 2.6 Weber 38 soon to megasquirt
1993 Eagle talon TSI Soon to megasquirt
boostin
Re: Ms1 v2.2 water injection help
Post by boostin »
Any one? Any help would be appreciated
Mike
benckj
Post by benckj »
I probably can't be much help but I will be doing same with WI control on my MSPSPv2. Guessing your MS1 has similar control functions as the MS2 versions?
Simplest method is to find an output control on your options plug which is based off MAP data. Something like option 1= boost control solenoid would work. The output could function as a switch to control a relay to pump. This will allow pump to start when certain pressure reached (ie 100kpa).
Hope that this is of some help. Maybe this bump will temp one of the experts to chime in.
jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Post by Matt Cramer »
It would help if you could be more specific about what parts of the directions you're having trouble with.
boostin
Post by boostin »
Basically the internal ecu mods, I seem to nut understand where I am soldering these components, what pins I am using on the db37.
Available pins on the DB37 on a V2.2 board are 25, 27, 29, 31, and 36.
25 connects to X11.
27 connects to X12.
29 connects to X13.
31 connects to X14.
36 does not have a connection point. Using it requires soldering directly to the DB37.
boostin
Post by boostin »
Ok I have a question, I was going to use x11, but many years ago I missed the ecu for edis, what does the wire from the led to x11 do?
Normal EDIS mods use this for the SAW (spark angle word) signal to the EDIS module.
boostin
Post by boostin »
But mine does not use that pin on the db37 that x11 connects to, is there a chance I did my edis wrong?
Please post a picture of the mods currently on the board.
boostin
Post by boostin »
hey sorry for the late respone, please double check th edis, been running for years so i assume its ok.
also would like to know what pin outs to use to solder in the ecu for the water meth pump control
Your mods are set up to bring the SAW signal out on pin 25.
boostin
Post by boostin »
ok so according to the wiring diagram on here
http://www.msextra.com/doc/ms1extra/MS_ ... m#waterinj
i connect to the open x2 hole but where do i connect to the 0v shown in the diagram and the 12v feed?
also is the feed coming out of the ecu to witch power or ground on the ecu?
boostin
Post by boostin »
any one?
Use the schematics to locate a 12V and a ground source.
boostin
Post by boostin »
ok, am i switching the ground on the relay or am i powering the relay?
boostin
Post by boostin »
also what is the emitter on the ground?
dontz125
Post by dontz125 »
boostin wrote:ok, am i switching the ground on the relay or am i powering the relay?
The relay coil should be powered by the main or fuel pump relay; the contacts can be powered by the FPR or direct to the battery. The MS is switching the coil ground.
boostin wrote:also what is the emitter on the ground?
Errr .... what? If you are using an NPN transistor, then the emitter is connected to ground. If that's not your question, I have no idea what you're asking.
boostin
Post by boostin »
all right guys, i guess i had a epic brain fart of how to wire this, so i have attatched my pictures let me know if this looks good. i used x2, xg2 for ground, and a un marked 12v beside x11 and x12.
should this be good to go?
