24-2 trigger wheel setting on ms1extra
Just confirming i can use my distributor that has 24 teeth, remove 2 opposite each other and telling the MS1 that i am using 12-1 crank signal.
Re: 24-2 trigger wheel setting on ms1extra
Yes.
Why not just remove one tooth and run it as 24-1?
That's what I did. It enabled me to run fully sequential COP ignition.
I'm guessing it's a Toyota.
Yes Toyota....but ms1 doesn't allow you to select cam/crank option..
It does, but setting up the wheel decoder for that is a bit more complicated and it's not a straightforward setting like on MS2/Extra.azaad wrote:Yes Toyota....but ms1 doesn't allow you to select cam/crank option..
