by renns » Sat Feb 12, 2005 8:15 pm
As long as you align the sensor properly to the wheel, it should work fine. I'm using a non-std sensor triggered by teeth cut in the outer rim of a pulley which is also much thinner than the stock wheel.
As an alternative, you could mount the sensor axially to read the side of the teeth as well.
