Hi Team,
I've got a Mazda 12a thats wired as per the Aaron Cake article except for the CAS which is a standard series 4 RX7 one with two missing teeth 180 degrees apart and the top "CAM" wheel not connected. I understand this is a common way to set these up.
Havent actually managed to get the car started yet. We suspected a spark issue so we thought we'd disable the trailing support to confirm my coil wiring but we got a settings error. Coils are four IGN-1A
Heres how they are wired.
Here is the error I got when I disabled Trailing support
And here is the MSQ If someone can advise where the confilct is or what setting is wrong it'd be greatly appreciated.
Thanks in advance
Steve
Settings Error in MSQ
