Looking for a base map to use with TunerStudio for a Ford 5.0 using the stock TFI setup.
My setup is just a mild build with a E303 cam, 24lb. injectors, Edelbrock intakes, cold air induction, Patriot Freedom heads (cfm is around 165), BBK headers, & a bigger Throttle Body (unfortunately I'm not sure on size as PO installed & there's no part #). Also when I went MegaSquirt I deleted the MAF.
Running a eMS-pro & any help would be greatly appreciated.
Ford 5.0 base map.
Re: Ford 5.0 base map.
Check these base maps out: http://www.megasquirtpnp.com/mspnp2_maps.php
Thanks, tried them but the MegaSquirt wouldn't run them. Tried all the Ford 5.0 maps & got 116 errors on each map when TunerStudio started up.BranSVT wrote:Check these base maps out: http://www.megasquirtpnp.com/mspnp2_maps.php
By the looks of it those maps are for MegaSquirt 2, will the MegaSquirt 1 extra run MegaSquirt 2 maps? I ask because DIYautotune has a base map on their website but it's for a MegaSquirt 2.
Just looking to get the car to idle but I'm a complete noob at this. The wiring wasn't to bad but the tuning is still a bit over my head.
Ohh I didn't know you had MS1. My bad. I don't think they'll run on MS1 unfortunately.
No, they won't. Your best bet is to use the MS1/Extra Tuning Manual: http://www.msextra.com/doc/ms1extra/MS_ ... Manual.htmBranSVT wrote:Ohh I didn't know you had MS1. My bad. I don't think they'll run on MS1 unfortunately.
