Just wondering if its possible to use MSnS settings instead of tfi settings on my ford sierra 2.0 pinto efi, with the tfi setup i'm having the exact same problem as in this thread http://www.msextra.com/forums/viewtopic.php?f=4&t=41211 And cant seem to get to the bottom of why its happening, with it set to msns there is no strange distributor or rev counter issues and i can get the car to start and run but dont want to run it if it will cause any damage to the tfi module or anything else?
TFI and MSnS settings
Re: TFI and MSnS settings
Problem solved, running msns settings now using tfi input signal with bip coil driver transitsor output with no probs, must be a bug on the tfi code
