CDI ignition and MSnS
aerowerks wrote: (not sure why since the MS'n'S-E cannot control more than four channels)
Who says it won't control 5 in the future!?!
From msns-extra.h
Code: Select all
coilsel:    ds  1       ; which coil are we working on
coilabit          equ 0       ; now a bit each to make life easier
coilbbit          equ 1
coilcbit          equ 2
coildbit          equ 3
coilebit          equ 4         ; can always hope
coilfbit          equ 5         ; can always hope
aerowerks
Post by aerowerks »
Sorry James, I shuld have known better. I'm a hardware geek that can barely keep up with you software guys. I guess I should start saving up for that Renault V10
Rick
ami8break
Post by ami8break »
Hello,
3 - 2 - 1 - zerrrrro...... DIY CDI project starts NOW! :)
We reworked the SC DIY CDI article and you can download at http://www.molla.org/DIY-CDI/ I found a Yahoo-Group for discussion: If you're interested in a DIY CDI please join http://autos.groups.yahoo.com/group/DIY-CDI/ When layout is fixed (in a couple of weeks) , I'll offer a groupbuy.
»Ho-ho-horst
MS1 V2.2 MSnSExtra 025x1 'EDIS' MT2.25b627, flat twin, MPI, dual ego feedback
_________________
DIY CDI project http://www.molla.org/DIY-CDI
risu
Post by risu »
Funny as I almost bumbed this topic up last night myself and now it's here. Personally I'd be more intressed in 2- or 4-channel CDI. I'll probably design my own PCB for testing. Planning to use 4 modified capasitor switcher circuits to do it.
-K-
ami8break wrote:Hello,
»Ho-ho-horst
Tiara Kit Car - MsnS-E
VolvoPentaMan
Post by VolvoPentaMan »
Sounds VERY interesting, i'll be needing a cdi ignition too for my wacko project, so i'll just follow this thread, since you seem to know something. :D
Some night i'll blow up the whole garage, when i misstakely connect myself to the cdi circuit. :lol:
My pals tought about my MS. project, "if that works, i'm santa claus", when i was soldering the board, and a couple weeks later, we went for a drive on my car with MS. :lol:
Volvo 340DL 2,5L 16valve turbo 408hp/664Nm Volvo Penta AQ171 Turbo 523hp/798Nm @ 2,3bar, AQ151 turbo 1,5bar 350hp/560Nm in boats.
_Adrian_
Post by _Adrian_ »
wow...
lots of progress i see :)
now i guess i have to hop onto yahoogroups again :D
Chopper
Post by Chopper »
I think I have all the parts to build a CDI box for my next MS project. It's going to be a 2-stroke single. What is the consensus for triggering the CDI box? At the moment, I'm inclined to use a VB921 and then use the points input on the CDI. Can anyone foresee a problem doing it that way?
Guy.
aerowerks
Post by aerowerks »
You don't have to use the VB921 to trigger the CDI box, but it makes for a good backup in case the CDI fails. Using points input is probably the best and simplest solution, I don't see any problems doing that.
