Re: Afr targets no longer stuck, ignt problems
I can t edit the afr target table, every feeld is set to 5,
Re: Afr targets stuck
Do you have "Lambda" enabled in your Project Properties ?
Yes, but it is in Volts, can you change this for AFR?
I can change them now lowere than 5 VoltVanhoe wrote:Yes, but it is in Volts, can you change this for AFR?
2.994 = 14.7 afr
I'm afraid I've destroid the sensor, it won't change from 3.04 Volt even after cleaning it and the thread came out when loosing it to!
new weld bung and sensor
It was the lambda controller that stopped working, feeling verry hot.
With new controller ok again.
When I applay the throttle only a smal amount in neutral MS 1 doesn't see the throttle moving and therefor going verry lean and stalls.
Is this something to do with Accl enrichment, or should / can I use MAP furst and switch to TPS like above 2000 RPM?
I think It wil see the MAP change better going of idle than the TPS movement.
Ivan
MS1 , single coil verry old engine from the 70'ies.
Ivan
Unless you have a very good reason to use alpha-N, do use speed-density.
I went for an other go this afternoon, already better throttle responce after adding some accl enrichment.
Unfortunally Sparks cutting above 4000 rpm.
Need to datalog this
Is it possible to use Hybrid Alpha_N on a non boosted engine.
I want to use MAP for the lower throttle bins and TPS for the higher ones.
I'm not sure that Hybrid is the way to go as it is more something for adding fuel under boost.
I've Always used TPS and never MAP before , those cars where Always racing applications.
This one is for going down the road with the wife and son.
Ivan
Ivan
Just use MAP.
I'll try it to use only MAP, I can't beleeve that wit MAP once the throttle is more than 50% open it changes mutch in KPa's.
Like I have now with the TPS in the first little movement of the throttle.
Well soon to be experimented!
I'm take a guess that over 95% of customers with a standard engine setup like that are using speed-density. What matters is whether the MAP signal is a good estimator of air mass ingested. For a "simple" engine like that with a plenum it usually is.Vanhoe wrote:I'll try it to use only MAP, I can't beleeve that wit MAP once the throttle is more than 50% open it changes mutch in KPa's.
I bet more like 99% of all installs are SD.
Tune your motor SD as perfect as you can get and then post about a 30 min log with the motor being driven fairly aggressively. It is easy to tell if you really need Alpha-N tuning.
Andy
Andy
I'ts like the ignition isn't following anymore.
Sometimes when accelerating, missing the ignition and all of a sudden pulls better and how more TPS the worse it gets
When I load an older tune I get a warning :
MSQ units mismatch for RPM4S! 10000RPM/Sec or 70% slip found in current config.....
What is that? never seen before
Can my logs be checked please?
When looging can you higlight a moment when the problem occurs?
Like putting a flag when you feel the problem in the car.
Afterworts you can see in the log where you had the problem and identifie the part in the log where you had the problem.
You can push the space bar while logging and this will leave a mark in the data log. This does not apply to tooth logs. It appears sometimes your ECU is not reading the first tooth after the missing tooth, based on the tooth log.
Vanhoe, your MAP signal has died.
Andy
Andy
running it Alpha N, MAP sensor not connected to manifold.
it shows 100 max to 96 min, schould be fine .
Cant seem to find the sync loss parameter in the logs
Placed new spark plugs , again, and she runs fine again!
I think the coldstart is to ritch and the plugs become to wet.
After a few starts the plugs are shot.
to be continued...
to be continued...
