I have an MS1 that has a MAPDaddy sensor installed. I bought it this way, and while I don't plan to actually use the MS1 with the MAPdaddy, I do want to try to figure out an issue I am experiencing in the setup of it.
So, MS1 029Y4, V3.0 board, MAPDaddy installed.
When I connect via Tuner Studio I see that the "Engine MAP" is reading 66 KPA, regardless of what map sensor setting I use. This seems to indicate that the sensor type is set to the 250 kpa sensor, not the 400 kpa sensor.
I see there's a MAP warning that states that Megatune must be used to enable 3 or 4 BAR MAP sensor types. I tried using Megatune and can't really make heads or tails of it and the only sensor types were 115 and 250 kpa sensors when I did get it to run.
So what am I missing here on how to set the MAP type with this MS1?
--==EDIT==--
I have noticed that if I change the sensor type, the spark advance will change, so it seems that internally the MAP sensor change is recognized but the gauge is not displaying correctly.
MS1 w/ MAPDaddy
MS1 w/ MAPDaddy
Tha Daily: 2005 Chevy Blazer
Re: MS1 w/ MAPDaddy
Ok, I figured it out...
The MAP settings under "Basic/Load Settings" seems to only set internal (to the MS) settings for MAP sensor use.
Going to File>Vehicle Projects>Project Properties and then clicking on the Settings tab allowed me to change the MAP sensor type there, which then seems to be a Tuner Studio setting to display correctly.
