During my initial testing with MS1 I got readings from coolant, air, tps, map, etc but could not get RPM. I double checked wiring , etc and also tried a pullup with 1k resistor. It is a distributor integrated type hall sensor with magnet so the wheel passes between the magnet and metal. I bench tested with an LED also and got no light without pullup and no pulsing with the pullup.
I just ordered a new Hall sensor that looks to be a match but my concern is that maybe 12v is too much? I can't find any definitive literature on the sensor to tell me if I should be running it at 5v or 12v but I have seen some information that some sensors are one or the other.
Anyone have experience with these that can tell me for sure if 12v is safe?
BRAND: AUTOPARTS TRADING
REFERENCE NUMBERS:
SIEMENS 2AV31E-J
BOSCH 1.237.031.296
BOSCH 1.230.320.062
BOSCH 0.269.053.592
VW 026 905 359 2
VW 030 905 065
VW 672 046
BOSCH 1.237.031.296 Hall sensor
Roketa GK-25A
800cc
3cyl
EFI
Single Coil Ignition/Distributor
Megasquirt 1 v2.2 - hi-res 11d FW
800cc
3cyl
EFI
Re: BOSCH 1.237.031.296 Hall sensor
This is the setup I started with about a decade ago, you're right, different places will tell you 5v and some will tell you it's 12v. Personally I've used both voltages on the same dizzy successfully. If i remember correctly the sensor is wired with a 12v feed, a ground and then the signal line to ECU. That signal wire being fed from a 5v source.
'82 Golf GTI ABF 16v MS2 Extra sequential COP
'77 Scirocco G60 MS2 Extra sequential
Thanks! Just got my new one and trying LED tests again with a 9v. Do you recall having to use an external pull up for this sensor?
Roketa GK-25A
800cc
3cyl
EFI
800cc
3cyl
EFI
No pullup is required, or at least not on the 'external' side of the opto isolator.
There's obviously a pullup on CPU side of the opto isolator, but that's just the normal megasquirt circuit.
Which schematic are you using for opto circuit?
That sensor was used in a lot of Australian cars. Certain model commodores and falcons. Yes they were 12v supplied in those applications. I have used one before but can not remember if they are open collector or inbuilt pull up. Easy to test with a multimeter.
Cheers Luke
Cheers Luke
