hi new here,, i come from Denmark and i have a big problem i have bin looking for days how to calibrate my new videband ..it is a bit of and the engine run bad.
it is a vw vento from 93 1.8 original monopoint ,, now 4 injektors and turbo
i have tunerstudios ms .. but is this the right one to adjust on ms1 exstra becors all methodes i have found to adjust it is a no go.. cant find a calibrate afr in tools or other places
any help welcome,,
regards jens
afr calibration
Re: afr calibration
Wideband EGO calibration is under tools. May need to enable it when setting up new project.
Jim
Jim
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Re: afr calibration
ok i have been looking for a place to unloock it but cant find it,, ???
Re: afr calibration
Not on MS1 it isn't. Project Properties -> Settings perhaps.
Re: afr calibration
ok thanks i will go have a look
