tach wire
tach wire
Putting ms1 with an msd 6010 for ignition on an ls motor. To tell the ms1 when to inject, I hook the tach wire from the msd 6010 to the ms1. Does anyone know what pin number in ms1 harness I should hook the wire to? Having no luck searching for it. Thanks.
Re: tach wire
I found the answer to my own question. Its pin 24. This is the thick shielded wire in ms harness. There are 2 wires in it, a black and a white. Hook msd tach output to the WHITE WIRE.
