Hello,
i'm starting my new engine project. It's Two cylinder Inline engine witch 270' crank. (get the sound like V2 engine). I'd like to run this on MS1, the question is, is that possible ?? What kind of tooth wheel i must use to run this engine 36-1 is ok ??? or i must make something special for this engine.
Inline 2 cylinder enegine 270 crank
Re: Inline 2 cylinder enegine 270 crank
I would use an MS2 (or MicroSquirt) - they have much better oddfire distributorless ignition control.
For now MS2 upgrade is not an opition. I have spare MS1Extra megasquirt and i'd like to use this stuff.
Soo this is my question is possible to run V2 engine odd fire (270' crank) on the ms1 ?
I can use any tooth wheel even som custom if needed, can machined on CNC anything. Just have to be sure that it's possible Run fuel & spark.
The notes about oddfire wheel decoding in MS1 are here:
http://www.msextra.com/doc/ms1extra/MS_ ... tm#oddfire
You can decide for yourself if this is something you'd want to attempt.
