HELP Needed..Truncated Temp Range MS1 029Y4 Fuel and Spark
However, when I close TS and open TS again,load the same MSQ, the X-axis goes back to 71C. Values for various Temp above 71C were truncated(missing)
Is there somewhere that I need to specify that I would like to have values above 71C(say 90C or 110C)
Thanks in advance for help to resolve this problem.
Re: HELP Needed..Truncated Temp Range MS1 029Y4 Fuel and Spa
From memory, I'm pretty sure that you cannot adjust those temperatures on MS1.
What happen to Prime PV when engine is cranked above 71C?
I believe there is some set value, else engine can't start, right?
Like most things in MS it will continue to use the last (71C) value for temps above.
