hi, has anyone fitted the MS1 V3 to a Renault L7X 24V V6 with VVT, its 2001 onwards and i am having trouble getting it to start, done the wheel decoder spreadsheet to get the trigger settings but still no joy, it coughs when i am cranking but doesn't actually fire up. its running COP with the BIP coil drivers and i have spark at all 6, also have fuel at all 6 so has to be a settings issue. any help massively appreciated as i am getting slightly fed up with trying all i can think of!!
CPS lines up with gap 14 at TDC so wheel decoder gave the following trig positions;
TP A - 4
TP B - 24
TP C - 44
running on time based to return trig positions left at 0
MS1 V3 on PeugeotES9/RenaultL7X 24V V6 VVT
Re: MS1 V3 on PeugeotES9/RenaultL7X 24V V6 VVT
finally got it running now. will post settings soon so others can use same set up.
does anyone know the best rev counter to use with COP setup? can a conventional rev counter be used or does it need a specific one to link to ECU?
cheers.
cheers.
hola, disculpa que moleste tanto tiempo despùes, podras pasarme los archivos con la configuracion que utilizaste para el V6 L7X?? y que software utilizaste?graciass.
