24 tooth + 1 tooth Cam but waste spark
mazdaspeed
Post by mazdaspeed »
Hi guys im sure this has been discussed over and over
The setup is a 24 tooth + 1 cam tooth built into the dizzy and wasted spark
So i can do the appropriate mods to accept the two inputs thays no worries
But can it decode the inputs and outputs ok
I assume the settings will run somthing like this???
Enable
Spark output A
Spark output B
Trig A 2
Trig B 8
Trig C 14
Trig D 20
Please let me know if this can work and what are my options for trigger angle???
Sent from my SM-N920I using Tapatalk
