Tuner Studio loses communication
Redneckrodshop
Post by Redneckrodshop »
MS1-EXTRA, fuel only, 334 cid SBC, Hillborn stack injection converted to EFI, 8-26lb hi-impedance Bosch Injectors, Mallory Sprint Mag.
Tuner Studio upgraded, on HP EliteBook 8730w, running Windows 7 professional 64 bit. DIY-Autotune USB to Serial adapter.
I can find and connect to the MS using the Detect button under Settings. When I try to drive the car and use Tune Analyze Live it loses comm and I get an Off Line error. Sometimes it will re-sync, but usually I have to go through the Settings Detect routine, sometimes several times, to get it to re-connect. I have taken the MS1 apart and examined it with a large magnifying glass, and cannot see any breaks in the connections at the serial port. I have tried a cheaper USB/Serial adapter, same results.
Does anyone have any idea what I should be looking at next?
Thanks for looking!
2017-07-29 WIDE BAND.msq
2017-07-29 WIDE BAND 18.08.32.msl
305 SBC bored .030, stroked 1/4" for 334 cid in a '23 Ford T-bucket
Crane Hyd Roller 509/528 lift, 284/292 dur
GM alum heads, milled for 10.25 c/r
Hilborn mechanical stack injection, I converted to electronic w/Megasquirt
Mallory Sprint Mag
MS1/Extra v2.2
2swe
Re: Tuner Studio loses communication
Post by 2swe »
is your USB to serial adapter bolted to MS port with USB cable running to comp ? if yes, you should stick your USB/serial adapter directly to comp USB port (or use as short as possible usb cable) and use a RS232 cable between adapter and MS.
1978 vw golf gti 16v itb cop full sequential MS2
1992 vw corrado 16v moonlight blue MS2
Redneckrodshop
Thanks! I was using the USB cable supplied with the adapter. Will change it and report back!
Mallory Sprint Mag
MS1/Extra v2.2
Redneckrodshop
Many thanks 2swe, removed the USB cable, plugged the adapter into the laptop, ran my old serial cable to the MS and so far, (knock wood) no Off Line errors!
Mallory Sprint Mag
MS1/Extra v2.2
