i wired in the table switching and used the positive leg of led 19 for the 5v external switch
any better place to take the 5v from the inside of the board?
i dont use it for a spark output (running edis 6)
seems to be working fine but would like some pro tip or something....
led 19 + good internal source of 5v?
2002 montero dakar rig
3.0L DOHC duratec / 6HP26
gt3582 boost to the moon
Ms3X soon to be running
dodge M37 look-a-like 1 ton
4.2l chevy atlas / 6R80
66mm turbocharger ~8#
Ms3X sequential finally kicking some butt
Re: led 19 + good internal source of 5v?
Generally, I take mine from the proto area.......
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
pretty sure ms1 has no proto awsomeness
hmmm seems to run fine but really low part or coast throttle goes very lean now
i am going to disconnect the led19 5v leg and see if it returns to my super rad tune of kick ass
What version board?turbothis wrote:pretty sure ms1 has no proto awsomeness
The 'positive legs' of those LEDS is via a current limiting resistor. For 5v from that area, you need to pick it up from the other side of D17's resistor - R23. Or from the 5v feed to your TPS in your wiring harness.turbothis wrote:i wired in the table switching and used the positive leg of led 19 for the 5v external switch
well then looks like i will try some stuff
thanks
thanks
