led 19 + good internal source of 5v?
turbothis
Post by turbothis »
i wired in the table switching and used the positive leg of led 19 for the 5v external switch
any better place to take the 5v from the inside of the board?
i dont use it for a spark output (running edis 6)
seems to be working fine but would like some pro tip or something....
2002 Montero dakar rig
FORD 3.0L DOHC duratec / 6HP26
gt3582 boost to the moon
Ms3X running and making fire!
dodge M37 look-a-like 1 ton
4.2l chevy atlas / 6R80
66mm turbocharger ~8#
Ms3X sequential finally kicking some butt
kjones6039
Re: led 19 + good internal source of 5v?
Post by kjones6039 »
Generally, I take mine from the proto area.......
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
turbothis
Post by turbothis »
pretty sure ms1 has no proto awsomeness
turbothis
Post by turbothis »
hmmm seems to run fine but really low part or coast throttle goes very lean now
i am going to disconnect the led19 5v leg and see if it returns to my super rad tune of kick ass
kjones6039
turbothis wrote:pretty sure ms1 has no proto awsomeness
What version board?
DaveEFI
Post by DaveEFI »
turbothis wrote:i wired in the table switching and used the positive leg of led 19 for the 5v external switch
The 'positive legs' of those LEDS is via a current limiting resistor. For 5v from that area, you need to pick it up from the other side of D17's resistor - R23. Or from the 5v feed to your TPS in your wiring harness.
turbothis
Post by turbothis »
well then looks like i will try some stuff
thanks
