Building ms1 v2.2 no tps signal passes but troubleshooting
Postby erikfromgilroy » Fri Sep 15, 2017 10:42 am
I'm having a dilemma of whether to move on to the output section or not because I'm testing my ms1 on megatune but the tps isn't working. How do I know if it's the stimulator or my ms1 before moving on.
erikfromgilroy
Re: Building ms1 v2.2 no tps signal passes but troubleshooti
Postby erikfromgilroy » Mon Sep 18, 2017 3:29 am
Could this be moved to the Boards forum. It's get some more traction there. I'm new here and eager to get this thing finished before I start the motor swap
erikfromgilroy
Postby DaveEFI » Mon Sep 18, 2017 5:08 am
erikfromgilroy wrote:I'm having a dilemma of whether to move on to the output section or not because I'm testing my ms1 on megatune but the tps isn't working. How do I know if it's the stimulator or my ms1 before moving on.
Check the voltage to ground with a DVM at the TPS input pin on the DB37. It should vary as you alter the stim pot.
BTW, best to use TunerStudio these days.
DaveEFI
Postby erikfromgilroy » Tue Oct 31, 2017 1:20 pm
New update. I did some stuff for Edis to work on my ms1 and now it won’t connect to tunerstudio. I did exactly the hardware mods listed on DIYAutoTune ms 1 v2.2 board and now no connection.
erikfromgilroy
Return to MS1/Extra support
Users browsing this forum: No registered users and 6 guests
