Building ms1 v2.2 no tps signal passes but troubleshooting
Postby erikfromgilroy » Fri Sep 15, 2017 10:42 am
I'm having a dilemma of whether to move on to the output section or not because I'm testing my ms1 on megatune but the tps isn't working. How do I know if it's the stimulator or my ms1 before moving on.
erikfromgilroy
Re: Building ms1 v2.2 no tps signal passes but troubleshooti
Postby erikfromgilroy » Mon Sep 18, 2017 3:29 am
Could this be moved to the Boards forum. It's get some more traction there. I'm new here and eager to get this thing finished before I start the motor swap
erikfromgilroy
Postby DaveEFI » Mon Sep 18, 2017 5:08 am
erikfromgilroy wrote:I'm having a dilemma of whether to move on to the output section or not because I'm testing my ms1 on megatune but the tps isn't working. How do I know if it's the stimulator or my ms1 before moving on.
Check the voltage to ground with a DVM at the TPS input pin on the DB37. It should vary as you alter the stim pot.
BTW, best to use TunerStudio these days.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
DaveEFI
Postby erikfromgilroy » Tue Oct 31, 2017 1:20 pm
New update. I did some stuff for Edis to work on my ms1 and now it won’t connect to tunerstudio. I did exactly the hardware mods listed on DIYAutoTune ms 1 v2.2 board and now no connection.
erikfromgilroy
Return to MS1/Extra support
