ms1 install on ford ranger with 88 2.3 turbo engine, lb3 ecu
Postby turbotankshane » Mon Oct 09, 2017 1:00 pm
I've got my ms1 coming in the mail, its going to be setup to replace the lb3 ecu, and I want to make sure the board is put together correctly for this application. What I'm getting is a
"MS1v3.0 board setup with the following
Opto input for crank sensor with 1k pullup
BIP373 single coil output"
but as a de-molested pcb
I've installed microsquirt on another truck I have and it runs great, but I've never messed with the pcb so I want to make sure I'm doing it right.
Anybody have any links to everything required for these installs? or tips on what to do and what to avoid?
turbotankshane
Re: ms1 install on ford ranger with 88 2.3 turbo engine, lb3
Postby Matt Cramer » Tue Oct 10, 2017 7:49 am
That is a bit of an odd way to build an MS1 for a TFI ignition. Normally it should be set up like this.
http://www.msextra.com/doc/ms1extra/MS_ ... al.htm#tfi
Return to MS1/Extra support
