Vibration Mega Problem
Postby German02 » Thu Oct 26, 2017 12:44 pm
Hey Folks
I will keep it short...
I run MS 1 on my 2JZ swapped E30 Drift Missile.
On my last Race the Car started to cut out randomly without reason.
Then on my last session,while Drifting the Engine died and never started again, after searching I realised that the injectors stucked open and shortly all cylinders,exhaust,intake,intercooler,Turbo and Air filter are flooded with Gasoline, who sweet was this. I wanted to log into MS but nothing happened. After 2 smooth claps on the Housing I realised that something was wrong inside..
After opening the Box (this Transistor 1) was lose inside. After searching I found the spot were it broke off. The other Transistor ( 2) had 2 pins broke. I welded them together again, cleaned the whole engine and it's running again.
My question is now did somebody know where the white cable goes (pic 2) and what else I should check
P.s of course now will mount the MS on Rubber mounts..
Thanks George
You do not have the required permissions to view the files attached to this post.
German02
Return to MS1/Extra support
