Coolant temp stuck around 100F
Postby mazzei14 » Sun Dec 17, 2017 6:41 pm
Hello, So I recently installed my home built MS1 v3.0 in my 86 rx7 with a 5.3 lm7 and a Muncie 4 speed. Car fired first crank and even idled, I was amazed. Megasquirt works almost perfectly, except the megasquirt will not read the correct coolant temp. The coolant temp gauge on the megasquirt ranges from 98-103F, even after running for 20 minutes or on cold starts (its 20 degrees here in NJ). If I plug in my stim, the guage works fine (however only reads 27-170F, which I’m not sure if that’s right?? ). I’ve checked my wiring to my coolant temp sensor and it’s fine (Resistance is the same at the sensor as it is at the db37 plug, I even bought a new sensor... no luck). I didn’t use easytherm yet, but I thought the megasquirt was designed to use factory gm sensors (my iat sensor and tps work fine). Anyway, any ideas you guys or gals have would be of great help. Also, am I supposed to solder in u1 (the big chip) or does it just get pushed in and stay that way (how I have it now). Thanks again
mazzei14
Re: Coolant temp stuck around 100F
Postby Matt Cramer » Wed Dec 20, 2017 10:45 am
It shouldn't need EasyTherm if using standard GM sensors. Does the CLT input work OK on a Stim?
Return to MS1/Extra support
Users browsing this forum: Google [Bot] and 1 guest
