My board is no longer functioning and it shows no response when the stim is hooked up , I noticed a trace was burnt leading to the d13 diode so I repaired that with a jumper sill nothing , I tested voltage regulator next , it showed full pass through of voltage over 5volt so I replaced it as well ,still get no function and the d13 diode is getting very hot . Any ideas ?
Ms1 v2.2 burning d13 and trace
Re: Ms1 v2.2 burning d13 and trace
Check if D15 or C15 is shorted.
