Knock Module connection
bravo685
Post by bravo685 »
Hi everyone, I was interested in the knock module as a standalone product. Can someone tell me what the pinout is for this board and what the boards output is. 0-5v or a digital signal.
Thanks in advance
Re: Knock Module connection
The MS3 knock module? It uses SPI and is only designed to be used with the MS3.
acab
Post by acab »
TPIC8101 ?
Manu
Post by Manu »
Yes
https://www.megasquirt.fr
acab
Post by acab »
jsmcortina wrote:The MS3 knock module? It uses SPI and is only designed to be used with the MS3.
Its possible to connect own knock module? Its same by schematics....
grom_e30
Post by grom_e30 »
in the firm ware there is a note
NOTE! This Feature is only Licensed for use with JSM add-on board
so may be breaching that.
acab
Post by acab »
yes. i know
but its 1:1 module ;(
Even worse then.
acab
Post by acab »
jsmcortina wrote:Even worse then.
Why? All schematics from datasheet of HIP9011/TPIC8101
acab wrote:Why? All schematics from datasheet of HIP9011/TPIC8101
The firmware to support the knock module was written to support the sales of the knock module - the two go hand in hand.
If you want to use the knock module firmware, BUY the knock module from DIYautotune or a sub-seller.
stevevp
Post by stevevp »
bravo685 wrote:Hi everyone, I was interested in the knock module as a standalone product.
Well done gents, I doubt there will be a second post
Steve
Steve, you know full well that Megasquirt is a commercial product and has been from day one, so what's the big idea?
Or was Bravo looking to try incorporating the knock module into some other device and just wanted to wire it up? I believe that is allowed; correct me if I'm wrong.
Using the firmware on the board Acab posted, though, would be a definite violation.
walterclark1
Post by walterclark1 »
There seems to be two significantly different questions in this thread. First:
bravo685 wrote:Hi everyone, I was interested in the knock module as a standalone product. Can someone tell me what the pinout is for this board and what the boards output is. 0-5v or a digital signal.
Thanks in advance
I read this as asking for enough info such that the Knock Module (as sold by DIYAutoTune) could be re-purposed as a non-MS device.
Then:
To me this reads. 'Can I put a different but electrically the similar knock module on an MS3?'.
A2 VW GTI 9A - MS3/3X
