Arduino-based CANbus gauge
Re: Arduino-based CANbus gauge
Still working on this off and on (life seems to pop up at the most inconvenient times) adding features, making things prettier/extendable. Thinking about designing a PCB around a teensy for stuff and giggles, now that they have a viable CAN library - make it standard OBDII compatible just for people to hack on.
https://github.com/kckr for some of the basic code. Apologies, just realized I never actually pointed a link to the code. The main gauge code (Squirtview) is.. pretty ugly. I'm starting to wrap my head around object oriented a bit better, so I've made lots of changes - but it all needs a refactor.
In the meantime - I 3D printed up a bezel and put the gauge inside the gauge cluster of my miata and made a simple demo mode.
https://www.youtube.com/watch?v=PyqZvAkLr4k
Running into some problems with the LC1 - or least, something that explains why my XD16 gauge stopped working correctly. Air/Fuel Ratio = ((lambda) + 500)* (stoich) / 10000 - for some reason my benchtop LC1 thinks that's 4.9 instead of 14.7. Easy enough to code around, but won't fix my XD16 (unless I start playing man in the middle). It is sorta fun burning pieces of paper to lower the oxygen content of a jelly jar to verify it's working - plus piece of mind knowing it's not sending bogus values to MS before I enable it on my car. I'll have to try reflashing once I find my cable/remember who I lent it to.
You can use an unlit butane lighter under the O2 sensor to get a rich reading. That might be more practical than burning paper. And if not then you have a lighter to light up the paper.
And I assume it's a typo but there is one '0' too many in the divider in your equation.
copy/pasted from http://www.innovatemotorsports.com/supp ... llog-2.pdf - though yeah, my code is actually LC1_AFR = ((LC1_lambda + 500) * LC1_programmed_AFR ) / 1000
That's because they use AFRx10, i.e., 147 for 14.7. That's obviously what you need to do if you work in integer-only but that can get confusing if that's not specified.
And the teensy CAN library does work fine with the MS protocol.
That's brilliant.bittertech wrote:Still working on this off and on (life seems to pop up at the most inconvenient times) adding features, making things prettier/extendable. Thinking about designing a PCB around a teensy for stuff and giggles, now that they have a viable CAN library - make it standard OBDII compatible just for people to hack on.
Nice gauge cluster too!
2003 MX5. Coldside MP62
Thanks - KG Works panel with revlimiter warbird gauges, and a PLX gauge in the bottom right, red gel over the odo, and wiped the needles with acetone and painted red with fingernail paint.
Finally got the LC-1 Serial read stuff (mostly) working. Finding out that three of my old LC-1's have a bad habit of redefining stoich to some garbage value (ie, 4.9), which explains my XD16 gauge problems. Might try to capture the serial stream that LGProgrammer sends to have my arduino auto-correct that condition - doesn't appear to effect the 0-5v reference, just the digital AFR data. Weirdness.
I've got everything loaded in the car and will be heading to the megameet this weekend if anyone wants to check it out in person.
Hi OP
First, I'd like to thank you for posting up the code you've written to make this - it's helped me get started on my own gauge (I'm using a Teensy 3.1 in stead of an arduino though).
Second, could you possibly show how you have the whole set up mounted to the gauge cluster as you've shown in the picture?
Thanks!
Thanks!
I've been reading through this thread, and I've basically bookmarked it.
I'm going to try to implement CAN comms with an Arduino Mega so I can have full suspension datalogging and DC motor control with the Arduino, while relaying the info both ways between the Megasquirt and the Arduino.
I just wanted to ask you, bittertech, if it would be okay to drop by and ask some questions, whenever I begin implenting this (obviously, I'll try to Google myself out of problems, but just to know if you won't hate me for threadjacking lol) in our Formula SAE car for 2015.
Last year at comp the Electrical Design judge loved our car, so let's see how it goes this year! I wanna show people that this ECU kicks all sorts of ass XD
I saw this gauge at the Megameet a week ago - very impressive work.
I wish I had more time to hang out at the megameet - a small emergency popped up and I had to leave. I couldn't even finish my beer.
Eldomino - sure, shoot me a PM any time with questions - I'm not on the forum too often but I've got email alerts on. I made a MSCan library that I need to push to github that might ease some of the functions with the MCP2515 - it is my first attempt at a library though.
humjaba - well, good news - on the teensy front I've begun to breadboard out the gauge components, about to start tackling the main bit of canbus porting. From there, PCB design begins.
The gauge was mounted with a 3d printed bezel and then glued to the panel. The neopixel ring just happened to be exactly the right size. The whole affair is in the car right now so I don't have pictures of holes cut and wires run.
Just as a teaser here are a few pictures of an initial prototype which uses hardware very similar to your last picture (plus a whole lot more). There is also code to control all of it. I'll have more details with the updated version.
Looking good also.
Do so much want! Make them buy-able over the winter please!
I would love to start with one (ore maybe more of those gauges in the spring!
fun is not a straight line
Sven
Sven
mmmm
JB I found the hw specs on another forum, so much stuffed there!
and also seems very customizable!
but sd, sensors and all that stuff wouldn't be overkill since megasquirt already does that?
http://i.imgur.com/qWGCL4e.jpg?1
http://i.imgur.com/HAcF8zn.jpg?1
http://monbazou.com/filedump/seb/diyecm ... G_0672.JPG
either ways these gauges are promising!
With such a small screen I prefer the one with neopixel ring, helps a lot to deliver info, being the oled so small.
_____________________________
Would the adafruit 1.5" color oled fit inside the pod, I mean physically, maybe trimming the corners of the board?
It would have such a lot more space! http://www.adafruit.com/products/1431
Maybe this one could fit better, 1.5" oled with sd, cutting out mounts (it's made for that):
dimensions 34.5mm across after cutting mounting tabs, 39mm from top to bottom and 6.8mm thick
https://www.tindie.com/products/miker/1 ... y-33v-50v/
I'm sure there are other available.
the plx dm-100 for example is 52mm and it uses 1.7" oled gauge... look at how many things it can show and big readable text!:
http://i4.photobucket.com/albums/y138/t ... 530-23.jpg
Robert
MS3x 1.4.1 | TS 3.0.28
Yes, these are images from Seb (93white3400z) who has done most of the firmware and all of the configuration software. There is a lot of flexibility and there's more to come. And I'm not sure of the hardware specs you saw because there is a lot of things but there should be very little, if any, overlap in the sensors between the gauge and the MS. And all the MS data is read over CAN.
There is no way to fit either of the 1.5" OLED boards you link into the case. But I agree that this would provide a lot more and I already had seen that. So what I have done is create a custom board that will fit and use the bare 1.5" colour OLED. So it will be possible to use either the small monochrome OLED or the larger colour OLED (at an additional cost). My board will use a surface mount connector on the bottom. And there is already a microSD card socket on the main board so there is no need for one on the OLED board.
And the 1.5" will cover almost as much of the gauge face as that 1.7" seems to do. So it should be possible to get almost the same effect.
That is quite superb Jean.
Is there an eta on availability?
Subscribing! Much want!
Sydney, Australia
1971 Holden Monaro HQ
I don't want to hijack this thread any further so that will be my last reply in this thread about that gauge Jean and I are working on. We're going to create on own thread in a near future. Status of the project is that I did prototype hardware with an Arduino Mega end of last year, Jean made prototype PCBs and we upgraded to a Teensy 3.1 and some other goodies early this year. Now, Jean fixed the minimal issues we had with the second prototype and added a couple more things and the PCBs are ordered. Jean will have to receive them, assemble a couple, send me one and I'll start modifying the firmware/softwares to fit the changes we did to the hardware in the second iteration. There is a TON of sensors on that gauge and some extra pins exposed to the connectors that allow for customization. I would say later this year is not impossible for a first batch of gauge to send to people but Jean and I haven't talk about that yet (because we're not quite ready).richyvrlimited wrote:That is quite superb Jean.
The gauge already includes a desktop application and Android application to control it. Code for everything will be available for anyone to customize to their needs. The desktop and Android application are both Java (desktop app should run on any platform) and share a common code base to make everything cleaner and avoid code duplication. The code is pretty well documented and I think decently written so it's not too hard for someone to jump in.
I've probably said way too much already so that's it for now
1993 Chevrolet Cavalier Z24
3400 Turbocharged Inter-cooled
MS3 v3.57+MS3X
MS3 v3.57+MS3X
That's a good update, looking forward to more news, in the meantime well done to both of you. Cool project.93white3400z wrote:I've probably said way too much already so that's it for now
Mike
Yamaha YZF1000 MSExtra 3.1
Well doesn't that look familiar...
As I don't yet have my megasquirt installed in my Miata, I got this gauge working with my Subaru. There are more interesting things to look at with that car anyway - it's turbocharged and I don't have boost, AFR, or temp gauges. SSM has a fast polling option and access to any variable in the ECU. So I'm going to get a couple of those OLED screens to replace the factory clock and information panel.
Where are you guys located? I'm only about an hour and a half north of suwanee on I85. I would like to see these in person too, if possible.
