CAN Communications.
Re: CAN Communications.
Im working away on my own dash display too.
At the moment im dumping the can transmissions between the MS3 and the TinyIOx.
Ive worked to how to format the header bytes, but the request data bytes are puzzling me.
An example of my can messages dump:
00->04 = msg_type:MSG_REQ var_blk:07 var_offset:0002 data(hex): 07 40 08
00->04 = msg_type:MSG_REQ var_blk:07 var_offset:0010 data(hex): 07 41 08
04->00 = msg_type:MSG_RSP var_blk:07 var_offset:0512 data(hex): 03 FF 03 FF 03 FF 03 FF
04->00 = msg_type:MSG_RSP var_blk:07 var_offset:0520 data(hex): 03 FF 03 FF 01 2C 01 2A
So, in the first request the data bytes are 07 40 08.
07 = myvarblk
40 08 = somehow is length & offset?
I gather the 8 is length, so that makes 40 0 the offset but shifted left by 1 bit?
IMO, the can_tech doc is too MS internals orientated.
cx_myvarblk, cx_myvaroff, cx_varbyt, etc dont actually specify where that data is located in a normal CAN message (ie, xx bits of the first data byte).
07 = myvarblk
It does, there's a diagram just under the wordsMWPau wrote:IMO, the can_tech doc is too MS internals orientated.
"The 29 bit CAN message header is divided into blocks across four 8-bit registers"
Yes, there is that nice table for the CAN header.
Something similar would be great for the format of the 3 data bytes of a MSG_REQ packet.
That's what I'm having trouble working out.
I updated the http://www.msextra.com/doc/ms3/can_tech.html page with some more information.MWPau wrote:Yes, there is that nice table for the CAN header.
Brilliant.
Thanks very much for that James
Anyone know if this page still exists?
The link is broken
The link is broken
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
Yamaha YZF1000 MSExtra 3.1
Where did you find that ^^ ?
These docs locations changes are frustrating
Actually, it's quite easy!
Manuals Index link and both CAN updates are at the bottom of the page.
Frustrating maybe, but the files have been updated recently, and I personally think stuff is getting much easier to find and is better organised than before, so I'd bookmark that link.
Mike
Go to the Frustrating maybe, but the files have been updated recently, and I personally think stuff is getting much easier to find and is better organised than before, so I'd bookmark that link.
Mike
Ah so it is
I only kept this page bookmarked, so missed it: http://www.msextra.com/manuals/ms3manuals/
