The traces handles at least 5 amperes per trace,they are 2.0mm wide.
There are 25 solder points with 3mm diameter pads, with 1mm holes.
The wiring loom from Megasquirt can be soldered in there.
The 25 pin connector is used by Bosch EZK 116K boxes and Digifant ECU's.
They accept maximum 18 AWG gauge, thats a wire with 1.024mm Conductor diameter.
Grundplanes for thermic relief are also on the PCB.
Sorry for the low picture quality.
Digifant/EZK 25 pin adapter board
Re: Digifant/EZK 25 pin adapter board
The Prototype PCB's was ordered today.
Any progress on this?
Thanks.
Jon.
Thanks.
Jon.
