Yes if you are running MS2 you can still use all the features that the MS2 offers including the CAN bus. The expansion processor can run ANY of the code that is written for the '908 processor, with the addition of the serial port tuning is IDENTICAL to MS1 or MSnS-E. The EXP board DOES NOT need any special s/w to run.
The only input signals the EXP board shares with the main MS processor (MS1 or MS2) are:
MAP
CLT
TACH
O2
MAT
TPS
BATT
The output signals from the EXP board are designed to drive an external power device. Upto 80ma from each output can be source or sunk depending on how you configure the output drive transistors. The 7 output transistors can be mapped to ANY of the GPIO pins including the PWM pins on the '908 processor, of course the processor pins must be set up as outputs in the s/w.
There are 3 types of inputs signals:
qty. 3 un-buffered inputs
qty. 4 opto-isolated inputs
qty. 2 analog inputs (permanently connected to the '908 processor)
7 inputs can be mapped to ANY of the GPIO pins on the '908 processor, of course the processor pins must be set up as inputs in the s/w.
So you have complete freedom to wire the EXP I/O to any of the available GPIO pins on the EXP '908 processor.
esv wrote:Very interesting!
As I understand, with this board one will have the advantages from both MS-2 and MSnS-E.
Will its tuning-procedure with MegaTune be the same?
If one is to use a MS-2-board with CAN, will it still be able to conect to the forthcoming router board as well?
You see, I am after a MS able to run a 5 cyl engine with fuel injection, coil on plug ignition and turbo-boost control!
Thanks in advance
ESV
