Almost squirted.......
Well I had luck, bad luck. It's all in, and would be done and running, but when I soldered a wire on the adapter board, I went to the wrong spot, and popped the board.
I can't believe I did it, and I'm a little miffed right now. Is this somthing that can be fixed Scott or am I ordering another board from ya?
I see what happened, when i told you to jumper the EEC pin 1 to the pad on the DB25 labeled SPARE1 you connected it to the DB37 SPR1, The wrong one. this put 12V directly to ground when you plugged in your Megqasquirt V2.2.
Look here, 12V and a V3.0 on pin 3 (the SPR1 wire) would have just gone to no where.
But you put 12V on pin 3 of the V2.2 Megasquirt, That made your adaptor board a fusable link.
Ok, well that throw's that theory out the window.
Double check your cable from the adaptor to the MegaSquirt and verify everything is all good there. You should have 12v on pin 28 with the key on, and good solid grounds on 1,2 and 7-19 from the adaptor board. You can check the fuel pump and relay by grounding pin 37 of the db37 with the key on.
Now that I would not have expected with a MS1 MCU.QuarterHorse wrote:I'll check tomorrow after work, but I had Jerry build the cable too. I also found out there was no firmwire and a friend of mine who's squirted his Mustang loaded that up for me.
By default the MS1 MCU should come with B&G v3.00 code in it as programmed by Al Grippo. That is unless you got MS2 which normally just comes programmed with the bootloader code, you can easily program either with Eric's MSDownload utility.
Sounds like the cable is wired backwards? That would make perfect sense given your readings.????QuarterHorse wrote:So nothing on Pin 28, but, when I check voltage on 20, I can make the fuel pump run by grounding the pin with the test light. Help me think, I'm just not getting this Scott, I'm sorry to be a pain but it's just no clicking.
I thiught i e-mailed you the schematic for your board, ok well anyway.
Here's the pinout of the trans connector j3 -
http://megascott.homeip.net/EEC-IV%20Ad ... nge4od.xls
Here's the schematic of the 1.21 board, be aware of the mods your board has for the ECU feedthrough.
http://megascott.homeip.net/EEC-IV%20Ad ... rV1.21.pdf
I put the schematics up on my site a few weeks ago. go to the assembly page of the particular board you have,
http://megascott.homeip.net/EEC-IV%20Ad ... ly1.21.htm
or
http://megascott.homeip.net/EEC-IV%20Ad ... ly1.30.htm
scroll down to the link that says
"Download the V1.21 Board Schematic"
"Download the V1.30 Board Schematic"
Sorry I don't have any pics directly on the site..Maybe something to add.
or
OK all my fault.
When the J2 Megasquirt connector was changed from a female to a male, to allow the use of the relay board cable, I forgot (like an id!ot) to check the fact that the pins are swapped end to end from male to female of the same series connector.
The fix for this is either to change the board (not likely now) or have everyone switch back to the female, and use a male end on one end of the cable.
For now Dustin will have to re-wire his cable, and I'll make the changes to my web site to suit, also I can get with Jerry at DIYautotune and have a special cable made just for my board, male on one end, female on the other.
