Peak and hold injector driver board
janse
Re: Peak and hold injector driver board
Post by janse »
Can i connect the MS3 card direct to the LM1949 chip? What kind of signal gives the MS3 card? inverted or not?
racingmini_mtl
Post by racingmini_mtl »
janse wrote:Can i connect the MS3 card direct to the LM1949 chip? What kind of signal gives the MS3 card? inverted or not?
Yes you can. The signal out of the MS3 is non-inverted. Use the J1 header.
EDIT: that assumes you have the p&h driver inside the MS3 case. If not you will need some sort of buffer to protect the CPU.
MS2tester
Post by MS2tester »
since you no longer have the V 2.0 peak and hold board
wat kind schematic would you need to turn the V 1.1 into intercept board for injector load signal ( universal)
racingmini_mtl
First let me say that I'm looking at having a replacement for the V2.0 in the not too distant future. I'm looking at 4 and 8-driver boards.
To use an injector output as the input of a V1.1 board, you need to add an inverter circuit between the two. This is an example of what can be used (you need one of these per channel):
You will also need a 5V supply for the V1.1 board.
MS2tester
Post by MS2tester »
maybe it,s an idea to combine these components in a V 1.1C board
and decide how you want to use it on how you hook it up ?
gruff511
Post by gruff511 »
Which peak and hold board out now is best to use with the ms3x?
racingmini_mtl
At this time there isn't a board available that's ideal to use with an MS3X but I should have something relatively soon. How many injectors were you looking to drive?
gruff511
Post by gruff511 »
Just 4 injectors. How soon are you talking? Im having trouble with big high z injectors and i think i should run low z since they react faster.
racingmini_mtl
Hopefully by the end of the month.
Wergilius
Post by Wergilius »
If I use this board I can connect it directly to the cpu outputs on MS2 with an v3 board for 4 cyl full sequential setup with low z injectors?
racingmini_mtl
Wergilius wrote:Hi,
You can connect it to the INJx point mentioned here: http://www.jbperf.com/sequential/index.html#v3conn. But you also have to do the modifications to the MS2 card and the V3 board mentioned on the same page: http://www.jbperf.com/sequential/index.html#ms2mods.
davcol
Post by davcol »
i am using ms2 V3.57 board sequential injection with jean peak & hold board along with sequential spark :D
m2 extra v3.57 3sgte full sequential injection V1.1A P&H Board
full sequential spark low current c.o.p.
holset turbocharger
Blades Rally Team
Post by Blades Rally Team »
Hi Jean
Will you ever have any peak & Hold boards available soon I have been trying to get my MS3 +MS3X working for about 3 years now all to no avail
Please HELP
Kevin Bennett
racingmini_mtl
Kevin,
It depends on what you call soon but they should be available again some time in July. Hopefully.
Post by jsmcortina »
How many do you need? I have a couple of bare PCBs here in the UK. I'd be able to ship them next week.
racingmini_mtl
Both versions (the internal V1.1B and the external V2.0.1) are now back online.
hvz
Sequential Injection
Post by hvz »
hi
i am going to modify the "MS2+PCB V3.0" to work with 4 cylinders in Sequential mode.
i have already read the tutorials here: http://www.jbperf.com/sequential/index.html#ms2mods
but i have 4 more questions:
1- is "Peak&Hold Injector Driver Board V1.1A" able to drive both high and low impedance injectors?
2- is there any schematic for "Peak&Hold Injector Driver Board " avalible?
3- will this work OK?
4- may i remove these part from the board?
D3, D5, D6, D7, D17, D18, D20, D21, C13, C14, Q1, Q3, Q5, Q9, Q10, Q11, Q12, Q13, Q14, Q15, R15, R18, R20, R30, R31, R32, R33, R34, R35, R36, R37, R38
racingmini_mtl
1. Yes.
2. You get a copy of the schematic when you purchase a board.
3. Yes for the injector connections once you have modified the MS2 card to get the 4 injector channels but you obviously also need to connect 5V and ground.
4. Yes.
Paul_VR6
Post by Paul_VR6 »
P&H v1.1 install for a 4cyl using ms3(x) outputs, fit in case.
Injector signals taken from bottom of jp1 on 3x side. Heatsink is tight to case sides for max heat dissipation.
Its tight, but it works. Decent solution for those that only need 4 channels.
Thanks again to Jean for the help!
-Paul
1992 Corrado SLC 3.6 VR6 11.38@120 - MS3 Pro Ultimate - Microsquirt I/O - Can EGT - Racepak IQ3s
elturbonitroso
Post by elturbonitroso »
I notice that you are using nylon screws to hold the transistors have you encounter any problem with the screw getting lose.thanks
