Are the VR sensors the right polarity?coyoteboy wrote:Glen - would having the trim pots on the VRs adjusted wrong stop me from adjusting my trigger position properly? Adjusting them seems to make no odds to whether it runs or not, but i cant adjust my trigger except by using the +22.5/+45 etc steps. + or - 10 on the trigger box and the timing light shows no change.
*error V2 assembled
1986 Porsche 944 Turbo
2.7 liter MID sleeved big bore, Wossner pistons, Vitesse Stage 2 turbo, coilovers, various weight deletes, and loads of other stuff.
As far as im aware, all share a common earth that Ive connected to the -ves of the polarity. G1 and G2 are tied to the +ve of one and NE to the +ve of the other. So i think so lol. But the knock one doesnt seem to do much either. I cant find info on how many turns they are max to min but i lost count of how many turns the knock one did around 15, it just kept going without even a hint of resistance.
Coyoteboy, My 2cents.
I have noticed the same issue with the VR pots on the MS 3.0 board, they seem to keep turning with no indication of a stopping point.
I did note this however, I could hear a small "click " noise that repeated once I went in one direction for ~10 turns.
I think that the "STOP" is just a small bit if plastic that is too easilly overcome by the worm gear torque and skipps.
I recomend actually measuring the pot with a DVOM and then keeping track of how many turns you are at.
Joe
Joe
89 accord 2.0L MS1 2.98 code v2.2 board, then MS1 and Megaspark, then MS&Se.
98 accord 2.3L MS&Se, v3.0 DIS.
99 Prelude soon to be MS&Se'd, turbo'd etc.
72 ElComino 406 sbc MSII v3.0 TBI
92 F250 MSI v2.2 MS&Se
92 twin turbo stealth MS&Se v3
*error V2 assembled
10 turn pots have been this way at least 20 years. No positive stop.
Joethemechanic wrote:
Thanks,
Eric Lee Elliott
eric@eric-elliott.com
http://eric-elliott.com
870.635.0201
245 Rainbow Drive #14559
Livingston TX 77399 2045
Posted by email.
--Coyoteboy, My 2cents.
Joe
This post is at:
http://www.msefi.com/viewtopic.php?p=140454#140454
Thanks,
Eric Lee Elliott
870.635.0201
Posted by email.
Caterpillar C9 400 HP Improved by EPA from 7.5 M/G to 5 M/G.
The reason there is no positive stop is to prevent damage to the pot by someone trying to turn it too far. There is a small "click" when you reach the limit. You have to listen closely on the 1/4" pots used on the Extra board.
BTW: I have the boards back in stock. I ran through the first batch pretty quickly. Jacob and I plan to keep these in stock continuously now.
--Glen
--Glen
