Moderators: daxtojeiro, muythaibxr, jsmcortina, MegaScott
racingmini_mtl wrote:Scott,
You're right, the grounds are isolated so if you want to apply 5V to the ADC part it's not a problem. However, that changes the circuit especially with respect to the bias resistor. If you think that this makes sense then go for it.
Cheers,
racingmini_mtl wrote: It can also be used with MS2 (MS2 code, microsquirt code, MS2/extra code) and/or MS V3.0 for an additional VR input and the ADC inputs.
turbodog wrote:Hello, Jean. I find myself in need of an extra VR input, as I need to run "twin trigger" mode plus I want a cam sensor. Would your board enable this? How would I use the 3rd VR input for ignition sequencing?
Thanks in advance!
kritip wrote://EDIT ----------- M is the package type, so i def need N. However i can't see what NOPB stands for :S ... is it purely a lead free package?
