I have now updated to the latest firmware (0.2) but now have an issue with entering values in the generic PWM output (as in firmware 0.1).
(from a previous post)
"As for the PWM table, this seems to be a TunerStudio issue. Earlier version worked fine but the latest version doesn't. I have found a workaround until Phil fixes the issue. Use the attache ini for the TinyIOx. It works here so I hope it works for you too."
question 1)
Could this still be the cause of this problem, behavior is exactly the same, no more than 1.6 is possible to write?
question 2)
I'm using virtual i/o and pte2 as an input but when looking at the realtime display it do not match, it seems to work correct
since the port1 is changing from 0-3 depending in inputs, maybe I have set it up incorrect?
question3)
is it possible to use pte2 in the output channel in programmable on/off outputs?
(i want to change polarity of the pte2 signal)
question 4)
if i log tinyiox.port1 in tunerstudio it works correct but remote port3 bit 0/1 do not seems to work, is it possible to log these?
i have not manage do find it anywhere (i'm using offset 45, table 7, can-id 4).
