Spark 'booster' (PNP circuit)
Postby jsmcortina » Mon Apr 02, 2012 12:05 pm
I have been testing out a circuit board that implements an improved version of the PNP drive shown in the MS2/Extra manual that is suitable for driving the VAG COPs.
The circuit could be used as an add-on to the MS3X to drive this type of coil or mounted internally within an MS2 instead instead of prototyping the additional transistors.
What I'm wondering is whether there's any interest in such a board for retail. Plus would it be best pre-assembled surface mount or supplied as a bare PCB for through-hole do-it-yourself assembly?
Re: Spark 'booster' (PNP circuit)
Postby tpsretard2 » Mon Apr 02, 2012 5:29 pm
i might be interested, my subaru cops have the same problem as the vag cops
tpsretard2
Postby colossusuk » Tue Apr 03, 2012 9:20 am
I'd like one of these boards if possible, at the moment I'm using a ford wasted spark pack but I would like to run VAG COPs on my VAG engine :)
Doesnt matter to me how it comes assembled or not - would assume it would be cheaper to assemble it ourselves?
Cheers,
James.
colossusuk
Postby Paul_VR6 » Tue Apr 03, 2012 6:47 pm
I would take a bunch. Pm me.
-Paul
1995 GTI VR6 MS3/V3
Paul_VR6
Postby BZR Se7en » Tue Apr 03, 2012 10:23 pm
Yes, I'd be keen in PCB form. As long as it had 4 coil drivers (or maybe 2), and maybe some other useful circuit like boost control or Tach, or 4 injector drivers for sequential.
In other words, a board that would be ideal for a 4 cyl VAG engine.
BZR Se7en
Postby jsmcortina » Fri May 04, 2012 2:52 pm
PCBs in and I've assembled a couple.
The board is designed to be used either internally screwed to the case lid or in an external box. It uses either a 5V supply or 12V supply with on-board regulator.
Postby lotus23C » Mon May 07, 2012 10:51 pm
What is different about the circuit to what is published in the manual?
thanks
lotus23C
Postby jsmcortina » Tue May 08, 2012 2:34 am
It contains current limiting on the output and has the input buffer transistors in place. It could be used externally from an MS3X or internally from the CPU in MS2 installs.
Postby teg » Tue May 15, 2012 5:58 am
I have just ordered a MS3X and I 'm running with 4 VAG COP's, so I'm interested! :)
Opel Kadett C City 2.0 16V Turbo
teg
Postby jsmcortina » Thu May 17, 2012 4:06 am
I'll put together some pricing in a bit.
Postby T3Bunny » Mon May 21, 2012 9:43 pm
I am also very interested. Has the extras manual been updated to reflect the improved circuit design? If not, would you be willing to post a schematic up here? I am currently upgrading to full sequential if I can sort out a reliable cam synch. If not, guess I will need to run a coilpack instead.
tpsretard2 wrote:i might be interested, my subaru cops have the same problem as the vag cops
Interesting, I can't say I have seen a Subaru with COP! But then most of the ones I work on tend to be older models.
Forget the porn, my bathroom is full of car manuals...
1977 Rabbit
1991 Cabriolet (retired)
T3Bunny
Postby tpsretard2 » Tue May 22, 2012 6:16 am
all STI's bar one model came with COP's
pre 99 was simple cops with external ignitors. the ms3 triggers these fine.
after that it has built in ignitors and the ms3 will not fire them directly.
tpsretard2
Postby jsmcortina » Tue May 22, 2012 8:08 am
OK, here's my pricing for this first trial batch. In GBP / USD
Bare PCB = £7 / $11.2
Loose kit of parts w/o wires or regulator = £9 / $14.4
Loose kit of parts w/o wires = £12 / $19.2
Assembled without regulator = £25 / $40
Assembled with 250mA regulator = £28 / $45
International postage at cost. Airsure to US is ~$12
Postby davcol » Tue May 22, 2012 5:35 pm
can this unit work with c.o.p. direct drive setup and boost its output :?:
m2 extra v3.57 3sgte full sequential injection V1.1A P&H Board
full sequential spark low current c.o.p.
holset turbocharger
davcol
Postby teg » Sun Jun 03, 2012 1:09 pm
Where is schematics for this? I would like to see it..
teg
Postby lotus23C » Sun Jun 03, 2012 4:46 pm
I never thought to ask before, this is for 3 pin dumb VAG COPs - right?
lotus23C
Postby jsmcortina » Mon Jun 04, 2012 2:50 pm
lotus23C wrote:I never thought to ask before, this is for 3 pin dumb VAG COPs - right?
Nope. 4 pin logic VAG COPs.
For 3 wire COPs you need an ignitor such as some BIP373s or the Quadspark from DIYautotune.
Postby davcol » Fri Jun 22, 2012 6:01 pm
Will this circuit drive the toyota denso 4 pin cop ignition coil with built in ignitor ?
If yes, what would process of purchasing? do you used paypal, that would be good. :D
holset turbocharger
davcol
Postby davcol » Sun Jun 24, 2012 2:46 pm
i would like try this on my project :D
holset turbocharger
davcol
Postby Matt Cramer » Mon Jun 25, 2012 5:55 am
davcol wrote:Will this circuit drive the toyota denso 4 pin cop ignition coil with built in ignitor ?
Usually the Denso coils don't seem to need a booster.
Next
Return to Expansion boards
