i'm tryin to design my own expansion board with an actual mbed controller. The modules should communicate via CAN. So what i wanna do is sending a REQ to ms2 and receiving data like rpm, clt,...
I've read the CAN technical documentation, and tried to understand how it works. I searched for the right ID's and now i'm faced with the problem, that i cant find the "configure outmsg" in my TS.
I found in old ms2 (notms2extra!!) Ini's this code:
Code: Select all
referenceTable = canOutmsgBurner, "Configure CAN Outmsg"
;topicHelp = "http://www.megamanual.com/mt29.htm#outmsg"
tableIdentifier = 010, "outmsg Table" ; id in octal, 010 = table 8
adcCount = 1024 ; length of the table
bytesPerAdc = 1 ; using bytes
scale = 1 ; scale before sending to controller
;tableGenerator = Generator Type, Label, xUnits, yUnits, xLow, xHi, yLow, yHi ; lows and Hi's are just default values, they will be user editable
;tableGenerator = linearGenerator, "Custom Linear WB", "Volts","AFR", 1, 4, 9.7, 18.7
solutionsLabel = "CAN Outmsg"
solution = "CAN Outmsg", { table(adcValue, "canOutmsg.inc") }
Am I on the right way, or do i think the wrong way?
Thank you, Christian
