DIY Drive by Wire controller project.
Re: DIY Drive by Wire controller project.
Post by Matt Cramer »
David - WI wrote:I'm just posting this link in case anybody is interested; I have MS3Pro but not drive-by-wire... I just got this in an e-mail this morning and wanted to pass it along: http://www.surpluscenter.com/New-Arriva ... 1-3493.axd
A drive by wire throttle pedal with only one sensor? It even looks like it goes through the entire 0 to 5 volt range with no sort of "out of range" value to report, meaning that any voltage from that pedal would be interpreted as a valid signal. No failsafes whatsover... yikes!
tpsretard2
Post by tpsretard2 »
There is some scary hardware.
Sometimes you just can't knock OEM hardware....!!
winstonusmc
Post by winstonusmc »
We just need to get James to let us in on how he put together the translator from CAN to UART serial to run the GM controller with the current code.
Nissan Skyline R34 RB26DETT ran MS3/MS3X w/ factory Hitachi CAS (sold)
Nissan Silvia S14 RB25DE ITB/NA ran MS3/MS3X w/ factory Mitsubishi CAS (disassembled)
Datsun 240z RB25DE ITB/NA with MS3/MS3X
machadohfls
Post by machadohfls »
Does anyone still have drive by wire files? Could you e-mail me? machadohfls@gmail.com
maisdc
Post by maisdc »
transaxel wrote:
dkgoodrich wrote:Can anyone revise the arduino code and translate it to English? Unfortunately most of us cant read the tags. That's how I learn haha
Is it possible to use this with one of the many motor driver boards that's ava for the Arduino's? Wouldn't that save us from having to build the circuit board the op has built?
I've attached a picture of "L298N Dual H Bridge DC Stepper Motor Drive Controller Board Module". These can be had for ~$5 off eBay. Isn't this essentially the same thing the op is building here? That drives the throttle motor from the Arduino?
Dumbed down, the arduino reads the pedal position via its potentiometer(s), sends a pwm signal to a motor driver, motor driver controls the throttle motor correct?
Any help would be greatly appreciated. I have a Arduino UNO, the L298N motor controller, a Subaru pedal and DBW TB
Keep up the good work!
At first: the L298 unit cannot handle the Power of an Throttlebody. Must hold minimum 3 Amps.
second: In the Attachment you find Arduino code with english comments.
Have fun, greetings Gerald
Hello transaxel, could you share the arduino code again to replace the PIC? Thank you.
cervan
Post by cervan »
Although this is an older post, if anyone is considering a DBW setup and is looking for a safe pedal, look at the 7.3 and 6.0 powerstroke TPS pedals, they adapt pretty easily into anything and the 7.3 has a single tps with an idle validation switch. This is safer than the one quoted above, as if you have any issues with the single TPS and let off the pedal it should fail safe into idle validation. The 6.0 that came afterwards uses two inverse output 0-5v tps sensors in an intergrated "apps" housing.
dll67
Post by dll67 »
Anyone tried using any of the standalone dbw controllers with their MS?. I've been searching for the last couple days and found a couple that look like they have the necessary safeties. Some others that sound to vague without further contact with them. More yet that I'm not sure if I would use in a stationary engine.
http://www.m-cal.com/Products/MC32-3140 ... Controller
http://www.dtafast.co.uk/dta_products/s ... ontroller/
. this one's a add-on module for adaptronic ecu's .. https://adaptronicecu.com/products/e-th ... rol-module
here's a h-bridge evaluation kit (Few safeguards) .. https://www.nxp.com/support/developer-r ... 3932EKEVBE
here's a computer module for driving throttles .. Doesn't look like it has all the safeguards it should either .. http://www.ni.com/pdf/manuals/Throttle_ ... M_RevB.pdf
here's some equipment more suited to diesel governor controls but should be adaptable to many applications .. http://www.mcs-belgium.com/files/MCS%20 ... merica.pdf
this has been discontinued by fueltech but i found new stock on several sites .. http://www.theefistore.com/index.php/sh ... ess-detail
this one sounds good .. http://www.turbofast.com.au/TFelectroni ... ntrol.html
definite maybe .. http://www.turbofast.com.au/TFelectroni ... ntrol.html
https://kms.vankronenburg.nl/kms-electr ... controller
Probably not .. https://www.ebay.com/itm/DBW-throttle-c ... 2447282666
ozmo engineering is supposed to have made a dual TB controller but i have not found them sold anywhere and there website is doa, here's a link to their Facebook page talking about it .. https://m.facebook.com/295748477116381/ ... _tn__=EH-R
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
Paul_VR6
Post by Paul_VR6 »
I have an ozmo up and running. Didn’t know they fell off the earth I need another.
-Paul
1992 Corrado SLC 3.6 VR6 11.38@120 - MS3 Pro Ultimate - Microsquirt I/O - Can EGT - Racepak IQ3s
dll67
Post by dll67 »
Paul_VR6 wrote:I have an ozmo up and running. Didn’t know they fell off the earth I need another.
Have you a thread describing your DBW setup ?
How about a pdf file on specifications and setup instructions for the ozmo controller that you would be willing to share?
Paul_VR6
Post by Paul_VR6 »
Not much to document its completely standalone from the ms other than using one of the tps outputs for the ms tps input.
-Paul
dll67
Post by dll67 »
Paul_VR6 wrote:Not much to document its completely standalone from the ms other than using one of the tps outputs for the ms tps input.
one tps input .. That doesn't sound good . What kind of safeties are built into it?
I assume it's CAN based?
since that's what the MS wants
How do you have it wired .. Does it take all the tps inputs?
Thank you for your time
Paul_VR6
Post by Paul_VR6 »
The controller itself has multiple inputs for dual pedal sensors and tps sensors. Just the one tps runs to ms for signal. Failsafes are programmable. Only used on track so far as I only trust oem for the street.
-Paul
