PWM converter modulate Fuelab41401
Im attempting to get me megasquirt 3.75 + X board running a 2jzgte sequential injection & Pulse Modulate Fuelab 41401. I'm looking for recommendations on wiring board to megasquirt.
Re: PWM converter modulate Fuelab41401
should be doable, set up a spare port for pwm and select a frequency that cam be multiplid by the pwm converter to be close to 1500hz, will probablu need pullup resistors. what i did was set it on low speed and had a spare port setup to switch in boost to high. works fine for me.
nevermind, I reread the pwm table and i was mistaken.
I use the pwm multiplier from Jean to increase pwm frequency, I don't know it that is still needed.
I connected the output to the fuelab pump, and also a pullup resistor going to the 12V. The values you put in the PWM table must be inverted compared to the load you want:
70% in the table means 30% for the pump: minimum speed.
15% means 85% for the pump.
I saw that I should not go below 30% for minimum speed, otherwise, the pump nearly stalls, or has erratic speed, and not above 85% for maximum speed: otherwise, it changes mode (goes from pwm to full load) and has a lost of pressure during a short moment.
You should try the settings by powering the pump and using TPS as pwm load to check how the pump reacts on all the range.
I use a frequency of 39HZ, multiplied by 32 = 1248Hz
http://www.msextra.com/forums/viewtopic ... 31&t=46488
Just wanted to drop a note here as well - depending on which generation pump you have the duty cycle might be reversed. On mine for instance, 10%DC is full speed and about 37-38% is low speed (just starting to sputter a bit). Contact Fuelab for help, but basically you can set this up using a voltmeter and varying duty cycle using the output test mode.
