Knock Module connection
Hi everyone, I was interested in the knock module as a standalone product. Can someone tell me what the pinout is for this board and what the boards output is. 0-5v or a digital signal.
Thanks in advance
Thanks in advance
Re: Knock Module connection
The MS3 knock module? It uses SPI and is only designed to be used with the MS3.
TPIC8101 ?
jsmcortina wrote:The MS3 knock module? It uses SPI and is only designed to be used with the MS3.
Its possible to connect own knock module? Its same by schematics....
in the firm ware there is a note
so may be breaching that.NOTE! This Feature is only Licensed for use with JSM add-on board
yes. i know
but its 1:1 module ;(
Even worse then.
jsmcortina wrote:Even worse then.
Why? All schematics from datasheet of HIP9011/TPIC8101
The firmware to support the knock module was written to support the sales of the knock module - the two go hand in hand.acab wrote:Why? All schematics from datasheet of HIP9011/TPIC8101
If you want to use the knock module firmware, BUY the knock module from DIYautotune or a sub-seller.
Well done gents, I doubt there will be a second postbravo685 wrote:Hi everyone, I was interested in the knock module as a standalone product.
Steve
Steve, you know full well that Megasquirt is a commercial product and has been from day one, so what's the big idea?stevevp wrote:Well done gents, I doubt there will be a second postbravo685 wrote:Hi everyone, I was interested in the knock module as a standalone product.
Or was Bravo looking to try incorporating the knock module into some other device and just wanted to wire it up? I believe that is allowed; correct me if I'm wrong.jsmcortina wrote:The firmware to support the knock module was written to support the sales of the knock module - the two go hand in hand.acab wrote:Why? All schematics from datasheet of HIP9011/TPIC8101
Using the firmware on the board Acab posted, though, would be a definite violation.
There seems to be two significantly different questions in this thread. First:
Then:
I read this as asking for enough info such that the Knock Module (as sold by DIYAutoTune) could be re-purposed as a non-MS device.bravo685 wrote:Hi everyone, I was interested in the knock module as a standalone product. Can someone tell me what the pinout is for this board and what the boards output is. 0-5v or a digital signal.
Thanks in advance
Then:
To me this reads. 'Can I put a different but electrically the similar knock module on an MS3?'.Its possible to connect own knock module? Its same by schematics....
A2 VW GTI 9A - MS3/3X
