The VND5N07 being rated at 5A, I guess it's not a good idea to use low imp injectors, so I'm using a JBperf board.
I've used the board before on a MS3X where I tapped in between the MS3 and the MS3X.
This is obviously not possible with the MS3 pro so I take it I need to build an invertor circuit to convert the injector outputs gnd to 5V signal.
Is this correct?
JBperf 4 channel injector driver and MS3-Pro
Re: JBperf 4 channel injector driver and MS3-Pro
Yes, it's correct.
thank you Jean.
