Thanks for the reply93white3400z wrote:SPI0 was renamed to KINETISL_SPI0 in newer version of teensyduino. The rest looks like warnings (easy to fix too).
Teensy-based CANbus gauge (and more)
Re: Teensy-based CANbus gauge (and more)
'82 Golf GTI ABF 16v MS2 Extra sequential COP
'77 Scirocco G60 MS2 Extra sequential
Soon I am going to try building one of these for my spitfire. I placed the order for the board from OSHpark and ordered everything except the GPS, Accelerometer, and 4k resistor. I do not plan on using the headlight sense atleast at first, and I don't need the gps or accelerometer.
This seems like a really good way to be able to keep an eye on certain functions without having a laptop or tablet hooked up all the time. I'll post pictures and results once I have everything in my hands.
Any updates? I'd love to build/use one of these.
Hi xrattiracer,
Have you considered putting in an oil life indicator with your widget?
I was looking to build an oil life indicator myself and came across your project.
With the setup you have, all that is needed is extra coding.
This Thesis paper has all the code done (in MatLab) and an indepth analysis of all the required variables.
https://etda.libraries.psu.edu/paper/9507/5943
Let me know if you integrate it as I am very interested.
no further updates at this time.
I am spending my available time on the low cost gauge project and more or less consider this one "done", at least as far as i plan on taking it.
Would u be willing to sell the gauge setup with GPS and such.
The faceplate stl is missing from the housing files.
Awesome setup though, I'm getting ready to build a couple of them.
1983 Toyota Celica GT-S MSnS-E
Wanna build me one I'll pay for itzipty842 wrote:The faceplate stl is missing from the housing files.
Hej Guy's,
does anybody run this code at the teensy?
All what I see are config errors all the time.
What is wrong with this code?
https://github.com/merkur2k/MSCan_Gauge/tree/teensy
Thanks for your time!
Golf MK1 Cabrio 1,8T MS2
412Hp at 20psi
412Hp at 20psi
Yeah you get config errors, but the author does admit that the code isn't perfect. The errors don't stop it compiling and working, or at least mine works.(see my post earlier in the thread regarding SP10)
At some point I'll work through the errors and see if I can fix some of them
What compiler are you use?
With the Arduino IDE + Teensy upgrade it doesn't run.
412Hp at 20psi
412Hp at 20psi
I'm also using the Arduino IDE with Teensy drivers..
Have you succesfully loaded any test code into the Teensy?
arg..
Yes, the Test run perfect. I've testet the "blink" and the Voltmeter. Both run without any problem.
I don't know, why it doesn't run...
Could it be, that the IDE 1.6.7 make a Problem with this code? Should I take another Version of the IDE?
The 1.6.5 doesn't run with my WIN7 and my Arduino Nano. The 1.6.7 does!
412Hp at 20psi
412Hp at 20psi
Well I'm currently using a version of the code that I modified so that it works as a GPS speedo, I recently compiled and loaded that onto the teensy using 1.6.7
So, we have fixed this thing!
Ok, "Alfagta" has fix it.
We use Teamviewer. On Win7 it doesn't run! No chance. How ever.
After a change to Linux mint the code run after a few minutes.
Thanks for your infos.
412Hp at 20psi
412Hp at 20psi
sorry about the bad housing stl file, i will get a new one up soon.
I am getting errors compiling the code as well. I pulled down all the libraries, I was going to just strip out the basic CAN stuff so I can read it with the Serial Monitor, but first I wanted to make sure I had a clean compile.
http://www.buildpics.org/
Man, I must have chased everyone off
Looking at your errors you must be missing a library, I got errors, but not those
Thanks, I'll pull down the libraries from GitHub again.mickeymarrows wrote:Looking at your errors you must be missing a library, I got errors, but not those
